Thetis 2.6.9 - audio set up tab - question
Posted: Wed Jul 08, 2020 10:02 pm
Hello;
I finally made the jump to protocol 2 Firmware and Thetis 2.6.9
I noticed the audio set up tabs are different in Thetis vs openHPSDR.
In openHPSDR there were three tabs under the audio set up:
Primary - VAC 1 - VAC 2
In the primary tab, you could set the buffer and sample rate for the input.
In Thetis 2.6.9 there are only tabs for VAC 1 and VAC 2
How does one set the buffer size and sample rate for the primary audio?
The goal is to be able to run as low a buffer size as possible to eliminate as much latency in the monitor as possible.
The old version I was running had a buffer of 64 and 128 (many other larger ones too)
I was never able to go below 128 on the buffer without getting audio glitches.
Hopefully I have been clear enough - if not, please let me know what other pertinent information I could add.
screenshots attached
