Thetis Lockup
Posted: Sat Dec 05, 2020 4:06 am
by N8ME
I haven't used my 7000 DLE (original blue case) for a few months. Today I downloaded Thetis 2.6.9 and Orion MK II Protocol 2 2.0b from the Apache Labs website. it was working well, then I starting fiddling with the settings and did something to where the radio plays for just a few seconds and locks up. I'm using VAC and the spectrum display freezes and the audio goes quiet. I'm using VAC and when it locks up, the TO VAC underflows are going up rapidly and the From VAC overflows are going up. Fiddling with settings or turning the software on and off, I could get the radio to play for a few more seconds. I reset the database and now the radio seems to be playing fine. It seems that there may be settings that are problematic. Are there any setting that I should avoid?
Mark, N8ME
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 12:15 pm
by NC3Z
There were several improvements above 2.6.9 in the many 2.7.0's versions that addressed many issues, and now 2.8.11 is the culmination of all those updates and fixes, maybe try that to see how it works for you.
https://apache-labs.com/community/viewt ... f=9&t=3557
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 1:54 pm
by N8ME
Thanks, I installed the 64 bit version of Thetis 2.8.11. It's working, but I've lost the waterfall. Whenever I select the Waterfall or Panafall displays, the waterfall portion of the screen is a gradiated blue.
Also, every once in a while, there's an audio hiccup and something read flashes in the status bar, but it's too brief for me to see. I check the SEQ log and see some entries, none with a negative VE value. The Status bar warning on -VE only is checked. Here's the most recent entry, just made after I heard an audio gap:
DCC2
s0=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:134017 l:133929 12/05 08:53:00:324
s1=0 0 0 0 89 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:121916 l:121826 12/05 08:52:00:324
s2=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 91 0 0 0 0 0 0 0 r:109815 l:109723 12/05 08:51:00:323
s3=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 91 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:97714 l:97622 12/05 08:50:00:323
s4=0 0 0 0 0 0 0 0 0 0 0 0 0 93 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:85614 l:85520 12/05 08:49:00:328
s5=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:49213 l:49211 12/05 08:45:59:840
s6=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 99 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 r:37210 l:37110 12/05 08:45:00:325
Mark, N8ME
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 2:32 pm
by NC3Z
There are long list of topics already on this so don't want to reinvent the wheel.
But a few quick things to configure:
Setup > Display Do you have DirectX selected and VSync selected under the Driver Engine section.
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 2:44 pm
by N8ME
Thanks, that helps. What topic should I search to find those other threads?
Mark, N8ME
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 4:04 pm
Mark,
I am willing to bet this is not a Thetis problem and that you have a version of P2 firmware installed that simply won't run (make timing closure) properly on your particular serial number. The problems you are experiencing are associated with receiving bad data from the firmware/hardware.
Start trying other versions of the P2 firmware that are available here:
Bootloader is the best way to load these.
Re: Thetis Lockup
Posted: Sat Dec 05, 2020 5:38 pm
by NC3Z
N8ME wrote:Thanks, that helps. What topic should I search to find those other threads?
I would start with a read through this thread https://apache-labs.com/community/viewt ... f=9&t=3345
