thetis PTT spacebar with other window open.
Posted: Mon May 17, 2021 3:59 am
by cleanrf
Does anyone know of a way to PTT thetis with it open in the background? Say I am rag chewing and looking at mousers website etc? It only works now when you place the mouse cursor on the thetis app.
Re: thetis PTT spacebar with other window open.
Posted: Mon May 17, 2021 11:52 am
My recommendation is to use serial port PTT. It provides the best ergonomics.
1. Add a serial port to your PC.
2. Assuming the serial port uses a standard 9 pin, D-subminiature, serial port connector, wire up PTT switch will connect pins 7 and 8 together when pressed. This can be a hand switch, foot switch, whatever.
3. Open the Setup window and select the CAT Control > CAT tab. Choose the correct port number for PTT control, RTS as the PTT signal, and check the Enable PTT checkbox.
Or you can use a MIDI controller and program one of the buttons for MOX.
Or you can use one of the many keyboard macro programs available and program a hot key or function key to always send a space character to Thetis no matter where the keyboard input is focused at the time.
Posted: Mon May 17, 2021 10:02 pm
by cleanrf
Thank you Scott.
