VST Host not talking to Thetis
Posted: Sun Aug 15, 2021 8:23 pm
Was reading your VAC tutorial on "Audio Interface and Digital Audio Workstation Software with openHPSDR" work. Although it is quite dated it certainly provides a good reference. I am using VMB ver.2.0.5.8 although I am also looking at ASIO Link Pro Tool that has been recently patched and it seems quite stable. Terminology is somewhat confusing to me and I don't always understand which In/Out needs to be connected to which In/Out.
I don't use a full-fledged DAW but a VST Host called Live Professor 2 (64 bit) which I have used quite successfully for many years. However, I do have actual DAWs downloaded as well, just in case.
I am at a point where I am ready to have my VST Host feed audio into Thetis. However, it seems like this isn't happening based on the fact that when I activate the Host nothing happens to the audio (there is no change whatsoever no matter which plug-ins I have engaged in my virtual "Audio Chain". I have a pair of head-phones plugged into the front of the 7000 DLE MKII.
Below, see a few screen captures (VMB, Thetis, WMM audio settings and settings inside the VST Host).
Must be something elementary that I am not getting
Using Thetis v.2.8.1/Windows 10/PC i7-10700 CPU 2.90GHz, 32GB RAM, 512 GB NVMe SSD
