Master AF adjustement/saving for Monitoring CW
Posted: Tue Oct 19, 2021 1:42 am
by JJ4SDR
Is there a handy way to have the Master AF level saved for use when listening to the side-tone when on CW? I am sure there must be. It is really annoying when I get on CW (have a pair of head-phones plugged into the front of my ANAN 7000 DLE MKII) and the volume is WAY up for the side-tone. I can adjust the Master AF level on the fly of course, but would rather have the level saved.
I have only recently started using the radio on CW and the proper way of achieving what I am writing about above may be quite self-explanatory.
Best!
Re: Master AF adjustement/saving for Monitoring CW
Posted: Tue Oct 19, 2021 12:44 pm
by G3ZQH
Hi Juha
If you go to the Transmit tab in Setup you'll see' Monitor TX AF'. Set this value to the volume which suits you for CW sidetone. I use 6, but yours might be different.
73 Dave G3ZQH
Posted: Wed Oct 20, 2021 12:40 am
by JJ4SDR
Thanks very much Dave! Mine was at 66 :o
73 de Juha
(OH1HX)
Posted: Wed Oct 20, 2021 1:16 am
The Master slider on the main UI will control this value when in TX. No need to drill down into the setup windows unless you want to.
Posted: Wed Oct 20, 2021 1:56 am
by JJ4SDR
w-u-2-o wrote:The Master slider on the main UI will control this value when in TX. No need to drill down into the setup windows unless you want to.
I realize that Scott but I don't like to have the side-tone blow my ear drums out when I don the cans and get on CW and much prefer that the level is set in anticipation of a bout of CW contacts :lol:
Posted: Wed Oct 20, 2021 10:52 am
Just trying to help since Dave was directing you to the setup menu.
Posted: Wed Oct 20, 2021 12:22 pm
by JJ4SDR
w-u-2-o wrote:Just trying to help since Dave was directing you to the setup menu.
I do appreciate it Scott!
