ARB-704 box to key linear amps
Posted: Tue Oct 26, 2021 1:59 pm
by JJ4SDR
I have an ANAN 7000 DLE MKII Black Edition (got it about 3 months ago) and have an Ameritech black box - ARB-704 - to key my external linear. Just wondered if any of you also use this “buffer box” to key your linear? Did you need to change the “jumpers” inside the ARB-704 to accommodate your 7000 DLE MKII? I guess I went through the ANAN manual too fast but I would imagine that the specs for PTT OUT will spell out what voltage/current levels it can handle.
73 de Juha
Re: ARB-704 box to key linear amps
Posted: Tue Oct 26, 2021 3:04 pm
by W4WMT
I use the ARB-704 to key my old Henry boat-anchor amplifier, using the 7000DLE MKII.
Works fine, no jumpers needed :-)
Posted: Tue Oct 26, 2021 4:05 pm
by JJ4SDR
I was talking about the internal jumpers (they look more like small switches) inside the ARB-704 as depending on what the PTT OUT on the ANAN 7000 DLE MKII likes to see you might need to adjust those switch positions.
Posted: Tue Oct 26, 2021 5:48 pm
I don't have an ARB-704, but I took a look at the manual for you.
On the radio side, you want the following jumper configuration, "RADIO (TX-SEND) = Low systems 2.5 volt threshold"
Posted: Thu Oct 28, 2021 12:58 am
by JJ4SDR
w-u-2-o wrote:I don't have an ARB-704, but I took a look at the manual for you.
Scott!
I do appreciate the information.
Posted: Tue Dec 14, 2021 4:19 am
by WR4N
JJ4SDR wrote:I have an ANAN 7000 DLE MKII Black Edition (got it about 3 months ago) and have an Ameritech black box - ARB-704 - to key my external linear. Just wondered if any of you also use this “buffer box” to key your linear? Did you need to change the “jumpers” inside the ARB-704 to accommodate your 7000 DLE MKII? I guess I went through the ANAN manual too fast but I would imagine that the specs for PTT OUT will spell out what voltage/current levels it can handle.
73 de Juha
I’ve had the same ANAN for less than a year. I’ve use ARB-704 on every transceiver / amp combination I’ve ever used. I actually use 2 of them because I use 2 amps (ACOM 1500 & ALPHA 89). They’ve always given me piece of mind.
