I have never worked on 10 meter FM using repeaters and I may need to get up to speed on how that works, but I wondered if any of you have done that. With improvements in general band conditions I would like to give this working mode a whack.
I didn't find a lot of information on FM ops in the Thetis manual.
73 de Juha
Working 10 meter FM repeaters
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
Protocol 2 v2.1.18
Re: Working 10 meter FM repeaters
Hi Juha,
just change mode to FM and then you see the options where you can configure repeater offset etc.
The config you see is for the HB9HD repeater on 29650, no ctcss, -100 kHz offset. You can program this in a memory as well.
András
András
Hello Andras!
Thanks a lot for the answer that turned out to be a sign of my being lazy . I should have just changed the mode to FM. I suppose I was thinking about how to set the deviation and so forth, but I assume that this, too, will be “self-evident” once I have the common-sense of switching into FM mode .
Best 73 de Juha
(OH1HX)
Best 73 de Juha
(OH1HX)
Protocol 2 v2.1.18
Protocol 2 v2.1.18
