To temporally solve the issue I select "Collapse". Then I select "Expand". This put everything back where it belongs. I'm curious if this is common problem or just mine. It's not a terribly important issue unless others are seeing it also.
Before i accidentally ran into the temporary fix I tried closing and restarting Thetis. Some times this worked, sometimes not. I also tried resetting the database. This didn't work at all. I would post a picture but the capture doesn't copy the cross. I don't find the problem annoying enough to uninstall and reinstall Thetis. Everything else is working extremely well so I will leave it alone.
