VOX is resisting!
Posted: Tue Dec 21, 2021 2:06 am
New 7000DLE owner here setting up the radio for the first time. Almost everything going well; a remaining issue is getting VOX to work. I have searched for an read quite a few posts here on this topic but so far havent found the answer, Here is where I am:
> Using virtual audio via VAC1
> Behringer B1 + UMC 204HD interface with Behringer ASIO drivers v4.9
> Thetis 21k7 + P2 v1.9
> VOX level indicator moving with receiver sounds and with my voice but VOX does not trip regardless of setting (with VOX enabled)
> Anti-VOX at -30 and makes no difference on or off
> Possible related issue: spacebar PTT is intermittent; sometimes it works and sometimes it doesnt. If I click on the MOX button, that works and the spacebar PTT then works for a while
> Have been through the VOX related settings quite a few times, and am using the settings Scott suggests here.
> Radio is otherwise working as expected. Several QSOs with good reports.
Same symptoms with Thetis 2.8.11 2020 version , and this is what motivated me to update to 21k7.
I have not tried a database reset so far.
Scott reports that the VOX works well with VAC so my issue is likely pilot error or perhaps a corrupted file somwhere.
Any guidance appreciated.
RICK
K8EZB
RICK
K8EZB
