RX Antenna Behavior
John K2OX
RX Antenna Behavior
Post by John K2OX »
I'm running v2.8.11 with P2, Angelia and custom hardware/modified code.
When I switch bands my receive is dead, noise at -145 on the Panadapter. Clicking Mox momentarily brings the receive to life. After that everything is OK until I switch bands again.
It turns out that choosing a different RX antenna and then RX1 also fixes it. I believe the root of the problem is that band changes don't query the rx ant selection until you transmit.
What I need is someone to verify this with standard hardware. I can put a fix in for my code, but if it is a bug, better to correct it for everyone.
John
Re: RX Antenna Behavior
Standard hardware does not do this. It is not a bug in the currently available Thetis or PowerSDR release, the public beta of Thetis, or any of the firmware.
John K2OX
Post by John K2OX »
Thank you.
