Orion Mkii (Anan 7000, 8000 series) RF input signal control map
Posted: Sun Jan 02, 2022 10:11 pm
This diagram came about in an attempt to understand how RF input signals are controlled in the DLE7000 mkii using Thetis. For example, how would one assign ADC_0 and ADC_1 to the DDC recievers if you wanted to use Rx1 in Thetis for FT8 and Rx2 to monitor CW on the same band (answer: assign ADC_0 to DDC2 and DDC3 so they are mapped to Thetis software receivers Rx1 and Rx2, use Rx1 for FT8 and Rx2 to monitor CW).
Much of the info came from Scott including the answer to the above question. As always sending thanks to him for his excellent help & gracious support. Also sending thanks to k9dtc who's question on another post promted the creation of this diagram.
Hopefully this will help others to understand how they can control RF input flow in the DLE7000 mkii using Thetis.
If there are errors, please let me know & will issue a revision. 73, Taiga
Revision history:
0.8 Jan 1, 2022 First draft
0.81 Jan 1, 2022 Changed titles on diagram & Thread per WU2O's recommendation below
0.82 Jan 4, 2022 Added Wideband display (WB display to ADC_0) per WU2O
Revision history:
