Thetis and Hermes 14 bit
Posted: Thu Feb 10, 2022 1:34 pm
by Mike_N1JEZ
I assume that Thetis has no problem running with the 14 bit Hermes boards?
I'm asking as I see there will be limited production run of these boards.
Tnx, Mike
Re: Thetis and Hermes 14 bit
Posted: Thu Feb 10, 2022 2:47 pm
Thetis runs fine with all available Apache hardware. It supports both Protocol 1 and Protocol 2 firmware.
With Protocol 1 firmware Thetis has the following limitations:
- no IF sample rate higher than 192KHz
- no stitched receivers.
In Protocol 2 there is no need for stitched receivers since IF sample rates of up to 1536KHz are supported.
Posted: Thu Feb 10, 2022 3:07 pm
by dl4zbg
Interesting Product!
Which firmware will be on the board?
The same as for the ANAN 10E?
Who will provide updates?
Posted: Thu Feb 10, 2022 4:21 pm
This isn't a new product. It is the board inside of the 10E and 100B. The update situation remains as it currently is.
It will almost certainly ship with Protocol 1.
See this topic:
https://apache-labs.com/community/viewt ... f=3&t=4051
