Thetis Skin Installer download
Posted: Sun Apr 24, 2022 2:12 pm
by DH1KLM
I have made a Thetis skin installer which includes 42 skins.
The skins were provided by IK3VIG, OE3IDE and W1AEX. All skins are up to date and therefore compatible with Thetis-v2.9.0.6.
The installer is about 34MB in size.
If someone has built a skin themselves and would like to pass it on, I'm happy to include it in the installer.
Feel free to download https://github.com/DH1KLM/Thetis-2.9.0- ... ns_big.exe
Re: Thetis Skin Installer download
Posted: Sun Apr 24, 2022 2:50 pm
by rbduck
I downloaded the installer. Yes all skins loaded and are available! Thank you much for the installer!!!!
Posted: Wed Apr 27, 2022 11:32 pm
by K9CDR
DH1KLM wrote:I have made a Thetis skin installer which includes 42 skins.
The skins were provided by OE3IDE and W1AEX. All skins are up to date and therefore compatible with Thetis-v2.9.0.6.
Feel free to download https://drive.google.com/file/d/1JMV9Rt ... sp=sharing
If you want to add this one I put together here I have attached it. If its not up to par, I wont take it personally :)
Posted: Thu Apr 28, 2022 6:07 am
by DH1KLM
Thank you Cory,
this is a nice skin. I'll add them to the installer, that's for sure.
PS: Skin already added.
Posted: Thu Apr 28, 2022 11:13 am
by Tony EI7BMB
I tried to download this but get warning below. When i click on "download anyway" nothing happens. Using Firefox browser. Not a big deal just thought you should know Sigi. Thanks for your work
Posted: Thu Apr 28, 2022 11:27 am
by DH1KLM
Hello Tony,
this warning is normal for bigger files which are downloaded from a google drive.
I am using Chrome and "download anyway" works for me without a problem.
Please try to download from https://github.com/DH1KLM/Thetis-2.9.0- ... ns_big.exe
Posted: Thu Apr 28, 2022 11:29 am
by Tony EI7BMB
That link works fine. Vielen Dank Sigi
Posted: Sun May 01, 2022 10:42 am
by dl4zbg
Helped a lot, TNX Sigi
Re: Thetis Skin Problem
Posted: Sun May 08, 2022 1:48 pm
by JPPNews73
Sorry to have to bug you for help, but I can't get the new sliders and features to show up. I uninstalled the previous version of Thetis, rebooted and installed 2.9.06. I then ran the new exe skins install file. It unpacked properly and seemed to run normally, but no luck. I subsequently deleted all skins out of the owner\AppData\Roaming\OpenHPSDR\Skins directory and reran the new exe skins install file. Still no luck. Thetis works just beautifully, but I do not have access to any of the new tools that are supposed to be there, no matter which skin I open. Any suggestions would be greatly appreciated.
73 JP, K5JPP
Posted: Sun May 08, 2022 2:17 pm
by DL8LAQ
JPPNews73 wrote:Sorry to have to bug you for help, but I can't get the new sliders and features to show up. I uninstalled the previous version of Thetis, rebooted and installed 2.9.06. I then ran the new exe skins install file. It unpacked properly and seemed to run normally, but no luck. I subsequently deleted all skins out of the owner\AppData\Roaming\OpenHPSDR\Skins directory and reran the new exe skins install file. Still no luck. Thetis works just beautifully, but I do not have access to any of the new tools that are supposed to be there, no matter which skin I open. Any suggestions would be greatly appreciated.
73 JP, K5JPP
Did you enable the Tune Slider in Transmit Menu?
Posted: Sun May 08, 2022 2:30 pm
by DH1KLM
Tried the installer right now 2 times. I could not face a problem.
Please try https://drive.google.com/file/d/1n1-EhJ ... sp=sharing
This one contains only 3 skins. Please empty or delete your skin folder and start the installer. It is a silent installer and has no GUI.
Posted: Sun May 08, 2022 2:34 pm
by DH1KLM
DL8LAQ wrote: Did you enable the Tune Slider in Transmit Menu?
Good point.
Posted: Sun May 08, 2022 2:37 pm
by JPPNews73
I figured it was probably something simple like that, and sure enough, all now works as designed, Thanks so much for the quick solution. Your help is greatly appreciated!
Posted: Sun May 08, 2022 3:03 pm
by va3cxp
Thanks for the installer Sigi!
Posted: Mon May 09, 2022 10:41 am
by 46flatlander
We're sorry. You can't access this item because it is in violation of our Terms of Service.
Find out more about this topic at the Google Drive Help Center. Google Drive ? Tried two machines ,one Linux and one Win11 any ideas ?
StarLink internet provider. Also both machines run latest Chrome Browser! Thanks
Posted: Mon May 09, 2022 11:19 am
Don't download it directly to a Google Drive storage location. Download it directly to your PC hard drive.
Posted: Sat Aug 27, 2022 3:00 pm
by DH1KLM
I created a new OpenHPSDR_Skins installer that copies the standard skins and s-meter files for the latest Thetis version from Richie to the appropriate directories.
If anyone needs them, here you go. https://github.com/DH1KLM/Thetis-2.9.0. ... _Skins.exe
Also compiled a Thetis installer from Richie's latest sources, which also contains the updated skin installer.
Posted: Sun Aug 28, 2022 6:02 am
by Chipp
Hi Sig, when trying to download the latest installer Windows defender reports the following:
Trojan:Win32/Sabsik.TE.A!ml
This program is dangerous and executes commands from an attacker.
file: C:\Users\Chip\Documents\Thetis\Skins Installer\OpenHPSDR_Skins.exe
I have made three attempts with the same result.
I thought it best to contact you before overriding the quarantine.
Posted: Sun Aug 28, 2022 6:57 am
by DH1KLM
Hmm..tested the file in virustotal and a few other online tools as virus free.
Maybe a false positive rating?
I will do some other tests. Thanks for your warning.
Posted: Sun Aug 28, 2022 12:47 pm
by w9ac
Downloads OK here. No warnings using Microsoft Edge.
Posted: Sun Aug 28, 2022 5:02 pm
by Chipp
w9ac wrote:Downloads OK here. No warnings using Microsoft Edge.
It appears to be a false positive when using Firefox.
I can download the file fine on two different computers using Microsoft Edge. Both computers give the false positive with Firefox.
Posted: Sun Aug 28, 2022 6:32 pm
by DH1KLM
Strange that my previous skin installer didn't cause this warning message.
Posted: Sun Aug 28, 2022 7:02 pm
BitDefender auto-deleted it for me.
