Frequency changes with resolution adjustments after transmit
rbduck
Post by rbduck »
This is loosely related to another today named "Can't adjust TX bandwidth using mouse". Reading that is how I came upon this. I
started a separate topic as I did not want to go off subject in the other.
I discovered this after I changed the spectrum resolution while I was in transmit.
I was in CTUN and performed a spectrum adjustment by clicking on ZTB
I then selected a frequency and then clicked on MOX.
While transmitting I clicked on the 0.5x,1x,2x or 4x buttons thus changing the transmit resolution.
After moving back into receive I clicked ZTB, I selected a resolution by clicking 0.5x, 1x,2x or 4x buttons.
When I select one of those buttons not only does the resolution change, but the frequency does as well.
In order t correct this, I have to close out of Thetis and restart.
Here is a short video demonstrating what I see... https://youtu.be/kNBwRoWcqW0
If this is one of the issues you are going to work on in the future just ignore this Topic :D
It is easily avoidable by NOT doing what I demonstrated. I've only adjusted the transmit resolution
one other time. Thanks.
Re: Frequency changes with resolution adjustments after transmit
Seems like the frequency change happens when you hit X1 whilst in TX @ 24 seconds into the video. Not sure why it would jump off to the left like that, very odd. Can't replicate it here in either DUP on or off. Will add it to the list of issues on github.
rbduck
Post by rbduck »
I'm going to reset the database and see if that helps. I haven't done that in a long time. I should have done that first. I'll report back after that.
Thanks again!
I think it is perhaps related to the pan setting that you have in RX.
