Palstar LA-1K RFI
Posted: Sat May 07, 2022 12:24 pm
by N3CAL
I just picked up a Palstar LA-1K Amp and noticed on the waterfall all the noise it generates when powered on. pics are with amp on in standby attached to a dummy load. Anyone else running a LA-1K see this?
LA-1K ON
https://apache-labs.com/community/downl ... ew&id=2905
LA-1K OFF
https://apache-labs.com/community/downl ... ew&id=2904
Cal / N3CAL
Re: Palstar LA-1K RFI
Posted: Sat May 07, 2022 2:06 pm
Wow! That looks so bad it the amp must be broken somehow
Posted: Sat May 07, 2022 3:46 pm
by alemrush
My opinion. Looks like a filtration problem from your dc supply ( 50VDC @42A , switching power supply) .
André
VA2WR
Posted: Tue May 31, 2022 2:28 pm
by N3CAL
I contacted Palstar and they refuse to do anything! They claim those signals are down more than -150db and would be a S1 signal which is no problem! With antenna attached I can hear those peak birdies and it's annoying!
Cal/N3CAL
Posted: Tue May 31, 2022 2:32 pm
Palstar needs to check it's math. The peaks are at -105, which is approx. S4. Those are big signals!
Posted: Tue May 31, 2022 4:55 pm
by kc2rgw
That is in NO way normal. I own an LA-1k and it's not even something I've ever noticed. Your amp likely has a broken power supply filter in it.
Posted: Wed Jun 01, 2022 12:12 pm
by K9RX
Wow indeed. That is horrendous and (the peaks) would be noticeable on any band except possibly 160M. Totally unacceptable - something wrong with the amp. Palstar needs to step-up and fix it.
Posted: Thu Jun 02, 2022 2:14 pm
by WR4N
I’m going out on a limb here ... but I’m guessing you bought that used. Correct?
Posted: Thu Jun 02, 2022 6:03 pm
by N3CAL
Hi David, the amp is brand new. I ordered direct from PALSTAR in January and received in late April 2022.
Cal / N3CAL
Posted: Fri Jun 24, 2022 11:43 pm
by N3CAL
6/24/22 UPDATE: I shipped amp back to PALSTAR for warranty repair. They confirmed the RFI issue when using the amp on 120 V. (I currently don't have a 240V drop here in the shack so it's 120v only for now). Their fix was adding a ferrite core inside the internal 50V power supply. The internal ferrite fixed the problem! No more RFI! Turnaround was just under 3 weeks. They mentioned they were going to add the ferrite FB77-5621 core to all their production units now. Most of their testing is done on 240v so it wasn't noticed during production. The amp is back in the shack and running great!
Cal/N3CAL
Posted: Sat Jun 25, 2022 12:28 am
Good news!
