Re: Thetis v2.9.0 - Updates and Issues AM missing
Posted: Fri May 20, 2022 9:34 am
by VK4BXI
Hi, before I go in hot and heavy and reload everything....has anyone had any issues with AM and SAM. Either I've done something silly with my setup but, when I decided to try and listen to an AM signal....no audio ditto SAM. DSB works as does everything else. And no output if I try and transmit. I'm running 7000 mkII with the latest thetis V2.9.0.6 and the latest P2 protocol. I am using Vac 1 for everything. Everything was working fine with the last version. I didn't try AM when I first upgraded to 2.9.0.6 so I can't be sure if it never worked or I have done something to beak it. Any thoughts ?
Regards Bob
Posted: Fri May 20, 2022 10:46 am
by kc2rgw
VK4BXI wrote:Hi, before I go in hot and heavy and reload everything....has anyone had any issues with AM and SAM. Either I've done something silly with my setup but, when I decided to try and listen to an AM signal....no audio ditto SAM. DSB works as does everything else. And no output if I try and transmit. I'm running 7000 mkII with the latest thetis V2.9.0.6 and the latest P2 protocol. I am using Vac 1 for everything. Everything was working fine with the last version. I didn't try AM when I first upgraded to 2.9.0.6 so I can't be sure if it never worked or I have done something to beak it. Any thoughts ?
Regards Bob
Go to Setup -> Audio
Likely the transmit profile you are using for AM doesn't have the VAC device selected or the TX gain set up properly. Select all you need and then re-save the transmit profile.
Posted: Fri May 20, 2022 11:05 am
by VK4BXI
Thanks I will try that
Posted: Fri May 20, 2022 11:14 am
by kc2rgw
VK4BXI wrote:Thanks I will try that
A quick fix, toggle the transmit profile to one that is working, save as "AM", set the bandwidth to say 5kHz and save again.
A bit ago some changes were made so transmit profiles are a bit more granular in the state that is kept, which is a good thing but it trips me up sometimes if making fast changes.
Re: Updates and Issues AM missing
Posted: Sat May 21, 2022 8:32 am
by VK4BXI
Got it thanks !
Regards Bob
