Recording Thetis while using CW Skimmer
iw7dmh
Post by iw7dmh »
I am wondering how can be recorded the audio and the screen while using Thetis and CW Skimmer.
I can't find a way to feed the audio stream to Bandicam because VAC-1 is dedicated to the I/Q stream and VAC-2 is dedicated only to the RX-2.
Thank you in advance for any help
73' Enzo
iw7dmh
Re: Recording Thetis while using CW Skimmer
CW Skimmer can use straight audio, although the bandwidth is more limited. So you could switch to regular audio, then split the audio using Voicemeeter or VB Cable into both CW Skimmer and Bandicam.
Another alternative would be to set both RX1 and RX2 to ADC0, turn on VFO sync, then use the VAC2 output to record audio in Bandicam.
A third, more old fashioned, alternative would be to pull the audio out of the headphone jack on the ANAN and send it to the mic input on your PC.
