Fatal Error
Posted: Sun Jun 05, 2022 2:58 pm
by NI0Z
Out of the blue I seem to get this Fatal Error (Screen shot attached) when I try to open Thetis. I have uninstalled, reinstalled, uninstalled reinstalled latest version, same result. I can no longer get past this fatal error when trying to load.
Thoughts?
Windows 11, 64GB RAM, i9 28 cores
Re: Fatal Error
Posted: Sun Jun 05, 2022 3:21 pm
by w9mdb
Try renaming the database in this location
C:\Users\[username]\AppData\Roaming\OpenHPSDR\Thetis-x64\DB_Archive
If that works attach the corrupted database file and maybe somebody can figure out a fix.
Re: Fatal Error
Posted: Sun Jun 05, 2022 6:30 pm
by NI0Z
Appreciate the reply, however there was no database to rename as it never loads enough to create one. I thought this might have to do with the 2 video cards, however, that is now ruled out. This is a Windows 11 issue. It looks like the older Thetis and the new one both have same issue with Windows 11.
Same issue on 3 different windows 11 machines, no issues on a win 10 machine.
Re: Fatal Error
Posted: Sun Jun 05, 2022 6:59 pm
Sorry but I have to ask this, are all of your Windows 11 machines 100% W11 compatible (and W11 was installed by Microsoft's updater), or did you possibly sideload W11 on your own?
I ask because if there's not 100% CPU compatibility with W11 then that might explain the difference in behavior between the operating system versions.
Re: Fatal Error
Posted: Sun Jun 05, 2022 7:13 pm
In Windows Settings > Display, try changing your scaling factor to 100% if it isn't already.
Re: Fatal Error
Posted: Wed Jun 08, 2022 12:29 pm
by NI0Z
Scalling was the issue. That messes me up in some other stuff, however I will find a way through it. Thanks and hoping that it can be addressed. 100% on a 4K 50 Inch display is literally a headache for the eyes.
Many thanks and yes, the machines are all Windows 11 compatible, no tricks, they are all relatively modern.
Re: Fatal Error
Posted: Wed Jun 08, 2022 12:56 pm
by w9mdb
Looks like it should be an easy fix actually.
I'd take a look at it but 2.9.0.3 is the most current version in the git repository.
Re: Fatal Error
Posted: Wed Jun 08, 2022 1:55 pm
NI0Z wrote:Scalling was the issue. That messes me up in some other stuff, however I will find a way through it. Thanks and hoping that it can be addressed. 100% on a 4K 50 Inch display is literally a headache for the eyes.
Glad I guess right :)
I run triple, 28", 4K displays. I use 150% scaling with no problem at all. Does 150% work for you?
Re: Fatal Error
Posted: Wed Jun 08, 2022 1:57 pm
w9mdb wrote:Looks like it should be an easy fix actually.
You are looking at the wrong repository. Look to Richie's GitHub repo here: https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.6. The source code is there for the taking.
You can also go to the top level of Richie's repo and see what else he is working on.
People would be very happy if you fixed this.
Re: Fatal Error
Posted: Thu Jun 09, 2022 4:58 pm
by w9mdb
Here's a new executable which hopefully fixes the scaling problem.
https://www.dropbox.com/s/7e40ygtnz7uhx ... s.exe?dl=0
Re: Fatal Error
Posted: Thu Jun 09, 2022 5:09 pm
Did you submit that back to Richie via his Git repo? He would certainly appreciate it if you did.
Re: Fatal Error
Posted: Thu Jun 09, 2022 5:15 pm
by w9mdb
Pull request has been submitted
