DXLab now supports TCP/IP CAT for Thetis
Posted: Fri Jun 24, 2022 1:59 pm
You will need to select the new rig type, "Thetis".
https://groups.io/g/DXLab/message/208761
Re: DXLab now supports TCP/IP CAT for Thetis
Posted: Fri Jun 24, 2022 5:33 pm
by W4WT
Great job working with Dave to get this implemented for us Scott! I look forward to giving it a try later today.
Joe W4WT
Posted: Fri Jun 24, 2022 8:11 pm
Thanks, Joe!
Re: TCP/IP CAT Server
Posted: Sat Jun 25, 2022 1:56 pm
by w2gs
DXLABS has been updated to run TCP/IP with Thetis. I have tried connecting Commander to Thetis using TCP/IP and have not been able to get the connection to work. Has anyone got this working? If so can you post screen shots of your setting in Commander and Thetis. I am running the latest beta version of Thetis. Thanks.
73, George
W2GS
Posted: Sat Jun 25, 2022 2:59 pm
George,
It would appear you did not notice this new topic in "Active Topics", so I moved your post here where we have a specific discussion of Commander.
If you are running Thetis and Commander on the same PC then generally (not always) you want to use 127.0.0.1 as the address, and make the ports match. In my example I use port 1881, but you can use the default port if you prefer.
Posted: Sat Jun 25, 2022 9:15 pm
by w2gs
I never saw the option for selecting Thetis as the radio in Commander. Got it working now. Thanks.
73, George
Posted: Sat Jun 25, 2022 9:25 pm
by W4WT
Working here thanks to your example Scott.
Joe W4WT
