No playback over the air after update
Posted: Sat Jul 09, 2022 3:44 pm
by ki4tga
After updating to Thetis 2.9.0.6 I cannot play back recording over the air to give my contact a sample of their audio. I can record them and playback ONLY if I am not ptt/mox. I'm not sure if this is a glitch or a setting has changed since the update. However I can see the recording is playing on the vox monitor bar while transmitting but it just isn't transmitting over the air. I do run VAC
Re: No playback over the air after update
Posted: Sat Jul 09, 2022 4:19 pm
Did the "Bypass VAC for recording playback" option accidentally become turned off?
Also, do you have "Allow MOX to override/bypass VAC for Phone" option turned on? This may need to be on.
Posted: Sat Jul 09, 2022 4:52 pm
by ki4tga
w-u-2-o wrote:Did the "Bypass VAC for recording playback" option accidentally become turned off?
Yes sir both are checked. I can transmit and record myself and play myself back over the air, just not rx.
Posted: Sat Jul 09, 2022 5:20 pm
I never use this feature, but I just tested it here with Thetis 2.9.0.6 and observed it to function flawlessly:
1. I also use VAC exclusively. I turned on both options as mentioned above.
2. Found a signal, recorded it using the REC button on the main UI.
<Switched to a dummy load since I don't need this actually going out over the air.>
3. Activated MOX.
4. Clicked the PLAY button on the main UI: this caused the recording to playback over the air (into the dummy load).
So I'm afraid I can't duplicate your problem :(
This brings us to the usual answer of "Did you try a fresh database?"
Posted: Sat Jul 09, 2022 6:01 pm
by ki4tga
I tried a old saved database. I did not try resetting the database but will now.. stand by
Posted: Sat Jul 09, 2022 7:17 pm
by ki4tga
Resetting the data base and reloading my data base fixed it. Ty sir for your time. 73 ki4tga
