7000DLE MKII - External Fan
Posted: Mon Aug 22, 2022 11:01 pm
by rdscuba
I have a PC case fan and the correct connector to add some external cooling. Right now I am running FT8 and the 7000 case is warming up well. I have a VM on the FAN power pins on the back of the 7000 and I am not reading any voltage at all. Is there a setting or jumper or something I need adjust in order to get power to this feature to work?
Thanks.
Re: 7000DLE MKII - External Fan
Posted: Tue Aug 23, 2022 3:10 am
by w9mdb
I see 12V on my 7000DLE MKII on that fan connector.
Posted: Tue Aug 23, 2022 11:55 am
There are no settings or jumpers. If it's not working then it's a hardware fault.
Is the internal fan operating? That fan and the external connector are wired in parallel.
Also, if your 7000 MKII is old enough, it may have the original fan PWM controller. If so that might be throwing you off. This was later replaced by a simple hardwired, always on fan configuration. See viewtopic.php?f=17&t=3622&p=12876
Posted: Wed Aug 24, 2022 12:36 am
by rdscuba
I never really hear the internal fan running, I presume it is quiet enough that might not hear it.
Posted: Wed Aug 24, 2022 3:29 am
by w9mdb
Nope...fan on the 7000 isn't that quiet....can hear it plainly....and can feel the air flowing too.
Posted: Wed Aug 24, 2022 9:33 am
I've got my 7000 tucked away behind a sheetrock partition just so my mic doesn't pick up that fan (my large diaphragm condenser mic can hear a flea fart next door).
