Need help!
Posted: Sun Sep 11, 2022 9:14 pm
by wa2cop
Its been months since I have used my rig. I had to rebuild my PC and started from scratch. I installed 2.9 Thetis. (have protocol 2 already installed working fine).
However, It will NOT connect if I select ANAN-7000DLE. It WILL connect on HERMES or others.
Any ideas?
Re: Need help!
Posted: Sun Sep 11, 2022 10:42 pm
by wa2cop
Had to delete the OpenSDR in my AppsData folder
Once I did that - reinstalled, no issues now.
Re: Need help!
Posted: Mon Sep 12, 2022 4:38 am
by va7qi
Are both radios on the same subnet? I have had the same problem here when both the Anan-7000 and Hermes are on the same subnet. I sometimes have to disconnect one radio when Thetis is trying to connect the other. Even if the radios use different firmware versions (or perhaps because of that?) this happens regularly. The fix is always to disconnect one radio temporarily and the problem goes away. It seems to be a problem only during the initial connect.
73 de va7qi, ....Erik.
