VOX vs N1MM voicekeyer question
Posted: Mon Oct 03, 2022 5:57 pm
				Guys,
I do a lot of HF contesting but only recently wanted to have the ability to use the voicekeyer function of N1MM for automated CQ calls.
The problem I'm facing is that I am unable to use the VOX function of Thetis in conjunction with the voicekeyer of N1MM, I either get one audio stream or the other, i.e. either the voicekeyer works perfectly but no life from the Mic/VOX audio, or the Mic/VOX works fine but then nothing from the N1MM VAC input.
I have N1MM configured to hard key the radio via RTS on COM2, again works fine.
The radio is Anan 8000DLE with headset going to the PC and fed to the radio using VAC1
PC is Windows 11.
Internal Sound Blaster Audigy FX card.
Thetis 2.9.06
I've tried both Voicemeeter potato/banana and good old VAC but the same problem persists.
I'm probably missing something really obvious, but I just can't see how to get both audio streams spliced together and hitting the radio without resorting to external cable/mixer.
There must be an easier way surely? Am I missing a Thetis setting, or do I somehow need to create a double-loopback within voicemeeter maybe? Can't get my head around it (=chemo brain).
Any help much appreciated.
Steve G1XOW
PC is Windows 11.
Thetis 2.9.06
Steve G1XOW
