AM TX low cut filter non-op
Posted: Mon Oct 10, 2022 9:45 pm
I have recently realized that the low cut TX filter in all AM modes doesn't do anything. It doesn't affect any change on the transmitted signal. However, the high-cut filter does work to control the ultimate bandwidth of your transmitted AM signal.
Is there a certain reason for this behavior, and does your Thetis work like this too? I checked on my Flex too and the TX low cut works properly on that system. This leads to a bit of an unclean carrier if your audio input contains any frequencies down low.
