Puresignal will not engage after Prot2 installed
Post by K9RX »
Radio: 8000DLE
Coupler: X-tronic
Software: 2.9.0
I've been using this version since April of last year with Prot1/2.3. It works fine, no outstanding issues. Puresignal has an issue, acknowledged and replicated by Richie, where it locks up but that can be overcome by, worse case, closing and opening the program.
I installed Prot2/1.8, been running it for a few days mostly CW and a little FT8. I just tried SSB and found that Puresignal will not engage. The dull green light to the lower right remains as such. The ATT values are where they'd normally be w/ the amp (but don't change with power). I've tried numerous things - none work to get it to come on. This includes an older DB as well as different TX profiles and of course cycling PS.
I went back to Prot1 and it works fine again. Suggestions please?
[note: I first tried the latest Prot2 which is version 1.9, it has an issue where the RX noise floor, when operating CW (TXing/RXing) all of a sudden goes to -29dbm and stays there! Thus my move to 1.8 which does not have that issue.]
Re: Puresignal will not engage after Prot2 installed
The latest Thetis is 2.9.0.6.
https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.6
The latest P2 firmware for the Orion MkII is 2.1.18.
viewtopic.php?f=32&t=3192
Upgrade both and then report the results.
Post by K9RX »
Thanks - I am using prot2/1.8 currently ... I'll try going to 2.9.0.6.
I did try resetting the DB (current version 2.9.0 and 1.8) to no avail.
You need to upgrade the firmware also.
Post by K9RX »
Yeah.... I see now I've been saying 1.8.... I THINK I have 2.1.18 but let me confirm that. Possibly that is where I screwed up. Be back in a bit.
g.
Post by K9RX »
How embarrassing... I haven't a clue why/how I was focusing on 1.8 ... I KNEW the latest was 2.1.18 - and thought I was there.
Anyway - thanks for your patience.
It is all working fine - my sincere apologies for the wasted bandwidth.
