piHPSDR on Windows
Posted: Sun Jan 15, 2023 12:06 pm
Hello! I would like to inform, there are Windows version of piHPSDR available
Vladimir EW8BAK in cooperation with Yuri EU2AV adapt it for Windows. Most fresh info will be available here:https://eu2av.ru/viewtopic.php?f=13&t=157&p=907#p907
Github with source code: https://github.com/ew8bak/pihpsdr
Short instruction: first of all you need to install the gtk3-runtime-3.24.31 library, then open the PihSDR_bin folder and run the pihpsdr.exe file, after which the installation will begin. Next, go to the network settings, and create a rule for incoming and outgoing connections.
Instructions are on Github as well. I attached installation file. GTK Windows library you can download here https://github.com/tschoonj/GTK-for-Win ... -win64.exe
By the way, work on linHPSDR on Windows are underway as well
I will inform about progress
