Newly Rcvd Anan-7000DLE MKIII & Installed Orion Board
Posted: Fri Feb 10, 2023 2:20 am
All,
I have a newly received ANAN from India, delivered on Feb 8th, that has ANAN-7000DLE MKIII marked on the Front Panel.
I am running Thetis 2.9.0.6 software successfully that auto recognizes the unit is on Protocol 1 firmware.
7000DLE has been selected in the “Setup ->General -> H/W Select” popout menu.
Thetis shows in the bottom right of the “Setup ->General -> H/W Select” popout menu the following:
Firmware
Ver: 2.8
Protocol 1
Some assumptions I have based on what I have read throughout the forums:
• Any new 7000DLE marked as a MKIII that was shipped after Jan 2023 will have the 5CEFA9F31 Cyclone V series FPGA. This is important to know and confirm as it affects the P2 firmware version that the unit is compatible with.
• It is my understanding, and I could be wrong, that the new FPGA listed above is associated with the newer Orion MKIII board that should be in any ANAN-7000DLE MKIII unit.
So my big conundrum:
• Given all the above, why am I seeing in the config screen under Firmware ID: Orion MKII?
• Is it because the firmware that is currently loaded will reflect such over that of what the hardware may truly be? In other words, if the firmware were upgraded and the HW installed is truly an Orion MKIII, would Thetis then reflect Orion MKIII within the “Setup ->General -> H/W Select” popout menu?
• Or do I have a new ANAN-7000DLE MKIII marked unit that was mistakenly equipped with an Orion MKII board over that of an Orion MKIII board?
• This also kind of ties into whether I truly have the newer 5CEFA9F31 Cyclone V series FPGA installed, or one of the two older FPGA series as that affects the firmware version that is compatible with my specific ANAN. In other words, what differences define what an Orion MKII version board is versus that of an Orion MKIII board?
• Or, am I just all kinds of confused regarding the rev of Orion Board that should be installed in a unit marked as a ANAN-7000DLE MKIII?
Any help in resolving my suspected confusion/observations would be greatly appreciated!
Thank you,
W5CUL
Firmware
Ver: 2.8
Protocol 1
Thank you,
W5CUL
