Losing VAC1 settings
Posted: Mon Feb 13, 2023 1:51 am
by JJ4SDR
Not sure why, but when I switched between LINE-IN and VAC1, returning to VAC1, the VAC1 settings had changed. By that I mean that the "Driver, Input", and "Output" had changed and I had to manually set them right, back to the original. When I go from a TX profile that employs VAC1 to a TX profile that does not, when using LINE-IN, the box to use VAC gets unchecked too. Why wouldn't the correct VAC1 settings populate automatically when I switch back to a TX profile that uses VAC1?
Re: Losing VAC1 settings
Posted: Mon Feb 13, 2023 3:23 pm
by W3MMR
Are you sure that you had VAC1 enabled before saving that transmit profile? All of mine that I use VAC with, are saved with VAC1 "engaged" and I havent had an issue
Perry
Posted: Mon Feb 13, 2023 3:37 pm
What Perry said.
Also, turn off the "Auto Save TX Profile" options in Setup > Transmit so that you don't accidentally change a profile.
Posted: Mon Feb 13, 2023 10:07 pm
by JJ4SDR
I always have VAC1 enabled. It is only recently that I have played with feeding audio into the LINE-IN where I don't have VAC1 enabled.
All AUTO Save boxes have been unchecked for as long as I can remember.
