Pure Signal, out-of-band improvement question
phaselocked
Post by phaselocked »
I got my Hermes 14-bit board a few weeks ago and am up and running with Thetis. But I still haven't received my 10w PA board.
In the meantime....I was thinking about trying out one of those cheap 70w PA kits from eBay, AliExpress, etc.
If I understand correctly, Pure Signal should improve the out-of-band spurious performance of a linear (i.e. second, third, etc harmonics) in the same way that it improves in-band splatter (signal width on the waterfall).
A question: is it reasonable to assume that Pure Signal can clean up the output spectrum of such an amplifier sufficiently that post-filtering is not needed at all?
Thanks and 73!
Dan
w9ac
Re: Pure Signal, out-of-band improvement question
Post by w9ac »
phaselocked wrote:If I understand correctly, Pure Signal should improve the out-of-band spurious performance of a linear (i.e. second, third, etc harmonics) in the same way that it improves in-band splatter (signal width on the waterfall). A question: is it reasonable to assume that Pure Signal can clean up the output spectrum of such an amplifier sufficiently that post-filtering is not needed at all?
PureSignal is not a substitute for an amplifier's low-pass filter. You'll need to ensure LP filtering is included with the amp you purchase, or build it on your own.
phaselocked
w9ac wrote:PureSignal is not a substitute for an amplifier's low-pass filter. You'll need to ensure LP filtering is included with the amp you purchase, or build it on your own.
Thanks, Paul. After your reply, I read https://www.analog.com/media/en/analog- ... cation.pdf. Clearly, my mental model of how pre-distortion does its magic was too simplistic.
That's a great article, Dan. I'm going to post that up separately in the sub-forum.
