Dissasembly of 7000DLE?
KA9UVY
Post by KA9UVY »
Ok, I've had this radio for over a month and still not sure how to look inside. After reading about chassis grounding and such I'd like to look inside of my 7000DLE MK2-3 whatever and verify the chip, check to see if the paint is cleaned off under connectors and screws etc.
I'd also like to see if I can flip the power switch over since it seems to be backwards to me.
What would be the proper way to skin this cat?
Thanks, 73
Robert
KA9UVY
Anan 7000DLE- MKIII
Thetis 2.10.3.5 u2
FW 2.2.2A
Protocol 2 v 3.9
73, Robert
KA9UVY
Re: Dissasembly of 7000DLE?
Robert,
The article at the link below is from about 5 years ago and shows the steps used to disassemble the case of the ANAN-100D. As far as I know the 7000DLE will not be much different assuming you have the extruded aluminum case.
http://anan-100d.wikidot.com/100d-disass
KA9UVY
Post by KA9UVY »
Thanks Rob, I'll give it a look, and thanks to Volker , DL4ZBG for sending me an E-mail with complete instructions in pdf format!
Now it's just a matter of time until my curiosity gives me the courage to explore the insides of this radio, and maybe the warranty has expired. :-)
73, Robert
KA9UVY
7000DLE DISASSEMBLY MANUAL[400].pdf
(486.55 KiB) Downloaded 415 times
Anan 7000DLE- MKIII
Thetis 2.10.3.5 u2
FW 2.2.2A
Protocol 2 v 3.9
73, Robert
KA9UVY
