Band and Frequency change
Posted: Sun Jun 11, 2023 11:03 pm
by ve2xx
I noticed when i use my Hermes with Thetis for transverter IF , i often go from one band to another following contest contacts ect.
Say i am on 144.200, i change band to 432.100 and want to go back to 2m to the same 2 m previous freq. the freq goes back to 144.250 and not .200
Am i missing something oin the setup tabs????
I don't recall having this issue using hpsdr,
Thanks Stu, ve2xx
Re: Band and Frequency change
Posted: Wed Jun 14, 2023 5:31 pm
The transverter bandstacks do not have default entries, and the default setting is to return to last used. Consequently it will always return you to start of band when you peform a band change if you have no updatable stack entries. Depending on config you can have it update an entry, return to a fixed entry, or return to last frequeny used in that band.
Posted: Sun Oct 15, 2023 7:47 pm
by ve2xx
Thanks works perfectly, Its not generally a problem for me IF im am operating one band at a time, like in a sprint, but when i have to jump all over the bands this becomes annoying,
just happen to read the reply you sent MONTHS ago!
Thank you for your reply, much appreciated!
73's stu ve2xx
