Page 1 of 4
Thetis starting with standard frequency
Posted: Wed Jul 26, 2023 7:58 am
by DG8DP
I'm using Thetis V2.10.0, so far no problems.
Since two days Thetis starts with standard frequency on each band in Mode CWL 1kHz Filter.
On exit the frequency and mode are not stored anymore.
Example:
7.150 kHz - LSB - 2.7 kHz
on next start:
7.010 kHz - CWL - 1 kHz
I can not figure out whats going wrong, any ideas?
Re: Thetis starting with standard frequency
Posted: Wed Jul 26, 2023 8:13 am
by DG8DP
Btw. in Band Stack 2 the option "Return to last used frequency" is choosen.
Wondering that this option changes to "Return to last entry" after restart.
I can see that after 4 seconds on a new frequency the V symbol getting green while saving the new frequency.
After restart, its gone...
Posted: Wed Jul 26, 2023 6:46 pm
by GW4NNO
I have the same issue. If I set the band stack option to "return to last used frequency", this setting is not retained on close and restart of Thetis.
Terry GW4NNO
Posted: Thu Jul 27, 2023 10:36 am
by DG8DP
Last night I removed Thetis from my PC and also delete all files and folders.
Afer rebooting system I installed Thethis v2.10.0 x64 and I didn't use an old database.
This installation was complete clean but I have the same problem again.
Anybody an idea how to proceed?
Posted: Thu Jul 27, 2023 4:28 pm
The way to proceed is to log a formal bug report here:
https://github.com/ramdor/Thetis/issues
The most important part of that bug report are the steps/procedure to replicate the problem.
Posted: Thu Jul 27, 2023 5:04 pm
by oe3ide
Cannot replicate the problem here (2.10.0).
73 de Ernst
Band Stack not saved on exit
Posted: Wed Aug 02, 2023 3:40 pm
by DG8DP
I send a bug report on github.
Meanwhile I figured out that Band Stack is not saved to the database.xml.
Going back to V2.9.0 there is no issue and the Band Stack is saved on exit.
Just for information:
Thetis V10.0.0 x64
Frequencies on the selcted bands are only avaible till the software is closed.
After restarting the software the before choosen frequencies on the selected bands are gone and
some other frequecies are selected form Band Stack 2.
While checking Band Stack 2 the frequency change is shown in that window after switching to
an other band. Coming back to the previos band the before choosen frequence is shown in the list and
VFO A. So far this behavior is ok.
After restarting the software this previus shown frequencies are not anymore in the Band Stack 2 lists.
**To Reproduce**
Steps to reproduce the behaviour:
1. Goto Band 10m
2. VFO A is 28.499.123
3. change frequency to 28.599.123
4. VFO A is 28.599.123
5. Switch Band to 15m
6. VFO A is 21.238.300
7. change frequency to 21.338.300
8. Switch back to 10m
9. Band Stack 2 shows 28.599.123 in list
10. Switch back to 15m
11. Band Stack 2 shows 21.338.300 in list
12. Power off
13. Restart the software
14. Band 15m shows 21.238.300 in Band Stack list
15. Band 10m shows 28.499.123 in Band Stack list
**Expected behaviour**
Thetis V2.9.0 works without this issue.
Checkung the database.xml I figure out the the changed frequencies are never be written to the bandstack section with v2.10.0.
Checking same with V2.9.0 the frequencies can be found in the bandstack section.
**System
Windows 10 x64 with all patches and updates provided by Microsoft update service.
**Additional context**
There is no problem in userrights to save / update the database.xml.
Posted: Wed Aug 02, 2023 3:45 pm
by DG8DP
Error log:
Entry : 5:42:34 PM Wednesday, August 2, 2023
Object reference not set to an instance of an object.
at Thetis.ucInfoBar.UpdateButtonState(ActionTypes action, Boolean bEnabled, Boolean bIncludePopup)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
at System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
at System.Windows.Forms.CheckBox.set_Checked(Boolean value)
at Thetis.Setup.AfterConstructor()
at Thetis.Console.get_SetupForm()
at Thetis.Console.ExitConsole()
at Thetis.Console.Dispose(Boolean disposing)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at Thetis.Setup.udpateTXProfileInDB(DataRow dr)
at System.ComponentModel.Component.Finalize()
Posted: Wed Aug 02, 2023 4:52 pm
by oe3ide
**To Reproduce**
1. Goto Band 10m
12. Power off
Still cannot replicate the issue.
Here (V 2.10.0 x64) on Win10 64bit it is working as expected. After Thetis-Restart 15m is on 21.338 and 10m is on 28.599.
73 de Ernst
OE3IDE
Posted: Wed Aug 02, 2023 5:13 pm
by DG8DP
Thanks for testing Ernst.
Terry has the same issue and I'm wondering that only V2.10.0 has this issue and V2.9.0 running fine.
Also tested with a "clean" install without import of the previos database, same issue.
The database is written on exit, I confimed this with changing PA Settings, they are saved on exit and can be found in the database.
Posted: Wed Aug 02, 2023 5:28 pm
by oe3ide
very odd...
To be precise:
I don't have these entries in the bandstack (which is correct, because I did'nt add it). But after a restart, bandswitch to 10m brings me to the last used freq (28.599) and switching to 15m brings me to 21.338.
But with the arrow down I see 21.338 and 28.599 (these "on-the-fly" stored values are used to get the last used frequency AFAIK)
73 de Ernst
Posted: Thu Aug 03, 2023 8:34 am
by GW4NNO
My system with Thetis 2.10.0 behaves the same as Chris's. The frequencies in the bandstand are not saved on exit and restart of Thetis. It is not only the frequencies that are not saved though. The choice of return to last used entry or last used frequency etc. are also not saved and return to the default setting after exit and restart of Thetis. There is a button labelled "Set" next to these settings which appears to do nothing at all! Is this button supposed to save the settings?
When I first installed Thetis 2.10.0 I deleted all the default band stack settings and started again with my own frequencies for each band. I wonder if that has something to do with the problem.
Terry. GW4NNO
Posted: Thu Aug 03, 2023 4:30 pm
by DG8DP
I did a new installation.
Configured the setup and have had a look to the Band Stack 2 list.
10m:
1) 28.005.000
2) 28.010.000
3) 28.120.000
4) 28.400.000
5) 28.450.000
VFO A is 28.005.000
Change to 28.500.00, after a few seconds the V shows green color.
Switching to 15m and back to 10m.
VFO A is still 28.500.000
Band Stack list:
1) 28.010.000
2) 28.120.000
3) 28.400.000
3) 28.450.000
5) 28.500.000 <<< Yes it is shown right in the list!
Close Thetis, wait a few seconds an restart.
VFO A 28.005.00 <<< Oh whats that? It wasn't in the list obove anymore
10m:
1) 28.005.000 <<< Wasn't in list before
2) 28.010.000
3) 28.120.000
4) 28.400.000
5) 28.450.000 <<< Where is the 28.500.000
This shows clearly with a new installation that Band Stack data is in the Memory but not saved to the Database.
Posted: Fri Aug 04, 2023 6:25 am
by vk1hx
I too have reported this issue with Thetis v2.10.0 in another thread. I started with a clean database each time.
Interestingly, on 40m Thetis seemed to remember the last used frequency. All other bands will always start at the beginning of the band.
I've reverted back to an earlier version (v2.9.0.27) and the issue is not experienced.
Posted: Sat Aug 05, 2023 1:17 am
by Dennis
Yes same here Thetis reverting back to First Start No database Imported, will NOT retain bands etc on start,
V2.10 64b ANAN G2, after opening ALL bands in CW and CW Freq,
I about to install THETIS V2.10 on a New Clean WIN 11 PRO 64B, 11TH GEN 64GB DDR4 I will report back shortly.
also no TX MONITOR as per the others.
Dennis vk4sx
TX / RX Relays ARE BLUDDY LOUD
Posted: Sat Aug 05, 2023 1:35 am
by Dennis
Ok NEW CLEAN PC Gen 11 64DDR4, i7 WIN 11 PRO 64
I removed Thetis V2.9
I left Data base etc
ran install Thetis Imported Older DB I had to hard restart,
Thetis is running started with 7000 in Radio, Changed to G2 no problems,
all DB info in correct and after MULTIPLE Restarts Thetis is staring referring to the DB NOT starting in original CW bands,
TX MONITOR worked Once only then after PC restart No more TX MON
MY MAIN concern was starting with CW band plan.
I believe switching A/B 2020 7000 to G2 Receiver appears to be quieter
Dennis vk4sx
Posted: Sat Aug 05, 2023 12:46 pm
by GW4NNO
Had another attempt with a clean install of 2.10.0 and a hard restart of Thetis for a new database. Band stack settings seemed to work at first but then reverted to not working after a couple of restarts of Thetis. I've now gone back to version 2.9.0.8 from MW0LGE and all band stack operations seem to be working fine again. I can now restart Thetis with my last used frequency already in the VFO!
Posted: Sun Aug 06, 2023 1:56 pm
by AndrewK
All working fine here, frequencies are saved and TX MON works with headphone on the front.
Posted: Fri Aug 18, 2023 4:19 pm
by pa1hr
After migrating to v2.10.0 I have the same issue. Some (but not all) settings are not saved after exit.
Before migrating to v2.10.0 I deleted all the old files and register with Revo Uninstaller.
When I restart Thetis v2.10.0 after an exit I get older frequencies (not the last ones) and modes in VFO A. VFO B is ok!
73, Hans.
Posted: Sat Aug 19, 2023 11:56 am
by W1AEX
Seems like Thetis for some users is not finishing its task of updating data to the the database and other files used for data storage in the users section of windows when it is closing. Could it be a permissions issue with windows? Just a long shot but is Thetis running with admin privileges?
Posted: Sat Aug 19, 2023 12:08 pm
by pa1hr
Could be yes.
I always start Thetis (and many other applications) as Administrator.
73, Hans.
Posted: Sat Aug 19, 2023 3:43 pm
by W1AEX
Hi Hans,
In the screenshot I can see that when I shutdown Thetis yesterday at 2:04 pm there were four files that were modified. I wonder if people who are experiencing this issue are seeing the same four files modified when they shut down. Could be the shutdown of Thetis is completed before everything gets updated.
Posted: Sun Aug 27, 2023 8:53 pm
by pa1hr
I really checked and tried everything, but since the last update(s) most of my important settings (like the workingfrequencies, etc) in the main display are messed around after exiting and restarting Thetis.
73, Hans.
Posted: Sun Aug 27, 2023 8:57 pm
by pa1hr
DG8DP wrote:I did a new installation.
10m:
2) 28.010.000
3) 28.120.000
4) 28.400.000
Same here, on 50 MHz. Thetis is messing around those settings.
73, Hans.
Posted: Wed Sep 06, 2023 2:59 pm
by DG8DP
@Rob
I checked the time and all 4 files as shown in your screenshot have the right time on exit, plus error log...
@Hans
Runnung software as admin is not a good choice and should be avoid if possible.
For testing it is ok...
I also tried to run Thetis as admin but no change.
I' still using an older version which is running fine.
Posted: Wed Sep 06, 2023 3:10 pm
by pa1hr
Thanks Chris!
I will give it a try. Perhaps the problem will be solved in future versions.
73, Hans.
Posted: Mon Sep 18, 2023 6:02 pm
by KD1GA
Same issue here, started after latest Windows 11 beta update that did fix the Direct-X meter sizing issues. I'm wondering if are using Windows 11 and if so what version.
Posted: Mon Sep 18, 2023 9:18 pm
by GW4NNO
I have the not saved band stack issue as stated above when using Thetis 2.10.x. I reverted to 2.9.0.8 and all works normally. I am using Windows 11 64 bit version 22H2. I have not installed any beta updates only final releases from standard Windows Update.
Terry GW4NNO
Posted: Mon Sep 18, 2023 9:37 pm
by KD1GA
Thanks for the response so I can rule out Windows hopefully. Guess I'll role the Thetis version back well
Posted: Wed Sep 20, 2023 4:02 pm
by DO2ZA Erwin
I have tested that, WIN 10 and Thetis 2.10.0.
BANDSTACK 2 is working fine !!
But the Arrows in the Top middle of Thetis are named QUICK RECALL, they are empty after a Restart.
Quick Recall is not stored, but Bandstack is ok. Two different Things, i think.
73 Erwin
