Scope Sensitivity
Posted: Wed Aug 16, 2023 1:40 am
by JohnFT61
Is there anyway to increase the sensitivity of the Scope in Thetis? It only occupies a small area of the vertical dimension of the display....
Re: Scope Sensitivity
Posted: Wed Aug 16, 2023 8:23 am
by oe3ide
These settings are your friends:
- settings.jpg (64.88 KiB) Viewed 3161 times
Posted: Wed Aug 16, 2023 10:37 am
Also, when you mouse over the vertical scale on the panadapter, the mouse icon changes to a hand. You can change the top and bottom numbers by left or right clicking and dragging up and down.
But wait, there's more...you can also mouse over the dividing line between the waterfall and the panadapter. The mouse pointer changes to an up/down arrow and you can left click and drag to adjust the split between the two displays.
You can also change the display mode to only show the panadapter by itself.
Posted: Wed Aug 16, 2023 6:27 pm
by JohnFT61
Sorry, I should have been a little more clearer. I meant the Oscilloscope display (Scope/Panascope...). I don't see a setting for the sensitivity (vertical scale). It occupies only a short distance that is available on the vertical scale.
Posted: Wed Aug 16, 2023 7:14 pm
by oe3ide
JohnFT61 wrote:Sorry, I should have been a little more clearer. I meant the Oscilloscope display (Scope/Panascope...). I don't see a setting for the sensitivity (vertical scale). It occupies only a short distance that is available on the vertical scale.
Maybe a screenshot would help.
Posted: Wed Aug 16, 2023 11:10 pm
by JohnFT61
- Oscilloscope1.png (883.28 KiB) Viewed 2989 times
As you can see the height of the waveform isn't as big as it could be! The window is much larger. It would sure be nice if one could increase the sensitivity.
John
Posted: Thu Aug 17, 2023 2:41 am
by w9ac
JohnFT61 wrote:Oscilloscope1.png
73 John
Scope sensitivity is a function of: (1) the Rx AF control; and (2) AGC Gain control.
