Mic input issues on G2 knobber.
Posted: Tue Aug 22, 2023 1:44 am
Could someone please help me figure out the following issue with my G2 w/front panel screen.
I have a headset with mic that uses a 3.5mm mono plug. Plugged into the front panel no audio with the TR plug and no audio with a breakout TRS plug in which the TR plug is inserted in the ring socket. Using Thetis Protocol 2 I experience the following:
1. If I plug the TR plug into the rear socket next to HP socket, it keys MOX and the audio is fine.
2. However, if I use the breakout adapter to avoid keying MOX then no audio.
3. If I add a ¼ RCA TRS adapter to use the so-called XLR socket no audio as well.
4. The front mic socket does not work with the headset mic using the TR plug or using the TRS breakout plug.
If I try all these combinations using only the front panel controls the results are the same except option #1 no longer provides any audio as well.
So I have not found any way in which to use my Heil headset with any of the 3 available mic inputs except using #1 with shorted PTT. Could someone please help me understand how to configure this mic with the G2?
The only mic I have that works is an old D-104 for which I wired a TRS 3.5mm plug, and that only works in the front socket; both rear panel sockets are inoperative with this mic.
Bill Diaz has been very kind in helping by providing diagrams of the pin outs for these various sockets, but they just don't seem to work with my mics.
Thanks in advance for any help.
-- Bob - Ki1n
-- Bob - Ki1n
