60 meters channel do not stay were you put them ?
Posted: Sat Aug 26, 2023 1:10 am
by mike b
ok ill try to explain it when you pick 60 meters say ch one 5.330.500 the radio tunes 5.330.600 if you correct it to what it should be 5.330.500 and leave to 80 meters and come right back it sets it at 5.330.600 again normally if you set the freq you can click threw the channels on 60 meters but with it moving them up .100 from 5.330.500 to 6000 they are all off i have tryed to correct them and save them but they do not stay at 500 they all are off when you return to 60 meters, has anyone found a work around? i normally go to my common use freqs just by clicking on the band button not so much any more , thanks 73 mike n8obu
Re: 60 meters channel do not stay were you put them ?
Posted: Sat Aug 26, 2023 3:32 am
by w9mdb
I found if you open the band stack window and unlock the entry you can then dial in a new one and "Update Entry".
Be aware what it's doing by default is avoiding the lower 100Hz (which you don't need for most any mode) and also sets a 2700Hz bandpass to give you 2800Hz total width.
