G2 and piHPSDR RigCtrl startup of CAT connection
Posted: Thu Sep 07, 2023 9:45 pm
by dl4zbg
this night I connected an USB to Serial RS232 adapter to the USB jack on the rear panel. I was not able to start serial communication (checkboxes for serial 0 or 1 could not be hit) - settings were preset to dev/ttyACM0 and ACM1.
Anyone tried this? Do I have to select settings on the pi before?
Any ideas/ thoughts would be appreciated.
Volker
DL4ZBG
Re: G2 and piHPSDR RigCtrl startup of CAT connection
Posted: Fri Sep 08, 2023 9:53 pm
by dl4zbg
Solved.
dmesg | grep usb
showed me the device name /dev/ttyUSB0 for the RS232 converter. Enable RigCtrl, Enable the serial port with correct baudrate (38400 for me) and now piHSDR is talking to my Microham MK2R+.
Cheers
Volker
Posted: Wed Sep 20, 2023 10:04 pm
by dl4zbg
Updated to release 9/19. After that update, CAT refused to work.
Anyone experiencing the same?
Volker
Posted: Thu Sep 21, 2023 10:27 am
by n1gp
Try updating pihpsdr again. I was actually working on merging in some
changes in the serial handling code on 9/19 which turned out to have a bug,
but the current (todays) should work OK.
Posted: Thu Sep 21, 2023 11:03 am
by dl4zbg
Thank you Rick! I really appreciate your work and your fast replies.
Posted: Thu Sep 21, 2023 11:07 am
n1gp wrote:Try updating pihpsdr again. I was actually working on merging in some
Hi Rick,
It's really great you are actively working on pihpsdr. You might consider starting a topic in the piHPSDR section discussing your work so that folks know what's new, what's fixed, and when it's ready to be used or tested.
Posted: Fri Sep 22, 2023 9:47 pm
by dl4zbg
CAT is back in operation, TNX Rick.
I fully agree with Scott. Developers of piHPSDR always update on Github and is not obvious for us "users" whether it is recommended to update from Github or not.
Volker
