Setup>Transmit "Mic Gain"?
Posted: Fri Sep 29, 2023 2:34 pm
by KC2QMA
Under the Transmit tab in the setup window there is a box labeled "Mic" an inside the box there are 2 controls for Gain MAX and MIN.
What do these controls actually do?
Screenshot 2023-09-29 102825.png (23.34 KiB) Viewed 4603 times
I understand there is a mic level control on the main screen of Thetis.
Please for give my ignorance ;)
Re: Setup>Transmit "Mic Gain"?
Posted: Fri Sep 29, 2023 2:53 pm
by NC3Z
Simple, it sets the Min and Max range of that front panel Mic slider.
Posted: Fri Sep 29, 2023 4:17 pm
by KC2QMA
NC3Z wrote:Simple, it sets the Min and Max range of that front panel Mic slider.
OK on the G2 it does not seem to control the level for the TRS balanced input.
I guess it's for the 1/8" mic input only?
Posted: Fri Sep 29, 2023 4:52 pm
by laurencebarker
The G2 mic goes into the same mic input after its balanced preamplifier; so yes those same controls will affect it. The preamp has gain, so you will need a lower gain than for say a dynamic mic.
Posted: Fri Sep 29, 2023 6:00 pm
by KC2QMA
OK I think I understand now, These adjustments don't control the actual audio level they control the range of the Mic level control on the main screen.
Correct?
Posted: Fri Sep 29, 2023 7:44 pm
by NC3Z
Yes, see my post above.
Posted: Fri Sep 29, 2023 8:20 pm
by KC2QMA
NC3Z wrote:Yes, see my post above.
Yes I see now.
Have a great weekend!
Posted: Fri Sep 29, 2023 8:21 pm
by NC3Z
Easy to test and see for yourself how it limits the levels.
Posted: Sat Sep 30, 2023 1:01 am
by KC2QMA
Does anyone know what the unity gain reference level for the balanced TRS input on the G2 is?
Normally the standard is +4db or -10db. What is the G2’s balanced TRS input?
