jtdx / wsjtx Installation assistance please
KK4X
Post by KK4X »
Hi Gang, I have my G2 up and running and wanted to get the correct settings for installing JTDX as well a WSJTX. I currenty have on my machine
VAC and VSPE. do i need to down load any thing else. Can someone take time an walk me thru this by telling me what goes in each blank.
I prefer to USE JTDX. i am running Thetis v2.10.2.1 downloaded JTDX V2.2.156
thank you for your time, I am missing out on 50mhz ft8 dx
Re: jtdx / wsjtx Installation assistance please
Typing "jtdx" into the search box on the forum here found the following topic which has a lot of good info:
viewtopic.php?f=16&t=4582&p=24175
I'd recommend using TCP/IP CAT rather than TCI, both approaches are discussed in that topic. In either case you will not need VSPE. You still do need VAC or some equivalent to move audio.
KK4X
Post by KK4X »
THANKS
Will give it a try.
