Monitoring of CW
JJ4SDR
Monitoring of CW
Post by JJ4SDR »
This isn't a real big issue, but I would like to understand why this is happening.
VAC used for audio and to hear the side-tone on CW, I am using a pair of head-phones plugged into the front headphone audio port. This works fine, except when I switch from SSB to CW, I will usually have to "tweak" the TX AF number (either up or down by just 1) on the Transmit form. Not sure why that is necessary.
Below, see a partial view from the Transmit form.
TX Monitor.jpg (6.41 KiB) Viewed 6507 times
Re: Monitoring of CW
What happens if you don't tweak it?
JJ4SDR
Post by JJ4SDR »
No side-tone
