How to connect Thetis to Ham Radio Deluxe via TCP/IP for rig control etc.
Posted: Mon Nov 27, 2023 11:25 am
by GW4NNO
Does anyone know how to connect Ham Radio Deluxe to Thetis via TCP/IP? I have Thetis connected to WSJTX via TCP/IP and that works great. I have the log book part of HRD connected to WSJTX and that also works, but how do I get rig control to work with Thetis and HRD?
Terry. GW4NNO
Re: How to connect Thetis to Ham Radio Deluxe via TCP/IP for rig control etc.
Posted: Mon Nov 27, 2023 11:45 am
AFAIK HRD does not support TCP/IP CAT.
Posted: Mon Nov 27, 2023 11:49 am
by GW4NNO
Thank you I was hoping that was not the case but at least now I know!
Terry GW4NNO
Posted: Mon Nov 27, 2023 1:04 pm
by w9mdb
HRD is going to rewrite their rig control logic in the future. They are actually completely rewriting HRD to be portable (e.g. Linux + MacOS)
HRD as of now should be able to connect as a TS-2000 to one of the Thetis CAT ports if you use virtual serial ports.
Posted: Mon Nov 27, 2023 1:27 pm
by GW4NNO
Thanks for that W9mdb. I may try cat via serial ports but don't have any virtual serial port software at the moment. I was hoping to avoid that! TCP/IP works so well with other stuff so lets hope HRD get it sorted soon.
Terry GW4NNO
Posted: Mon Nov 27, 2023 2:15 pm
by w9mdb
Use this
https://freecomportredirector.com/
Create a TCP/IP Port to 127.0.0.1:13013 (RAW) for example.
You can pick an available (i.e. empty) COM port for the redirector to use.
Set HRD to PowerSDR 115,200
Posted: Mon Nov 27, 2023 3:31 pm
by GW4NNO
Thanks Mike, I'll certainly look at that and give it a try!
Terry. GW4NNO
Posted: Tue Nov 28, 2023 9:37 pm
by GW4NNO
I now have this working following Mike's suggestions. I have rig control of my Anan7000DLE mk ii from HRD to Thetis and logging direct from WSJTX. Thanks for all the help.
Terry. GW4NNO
