Help: Cannot connect ANAN G2 to Thetis
Posted: Sat Dec 30, 2023 2:23 pm
Hi all
I tried booting my new ANAN G2 up for the first time and received a "Network Error: Error starting SDR hardware , is it connected and powered?" prompt.
I had connected the G2 to my router (via a Cat 6 ethernet cable) which then allocated it an IP of 192.168.1.76
I installed Thetis v2.10.3.5 x64 (12/27/23) u2 and under the Setup (H/W select) tab changed the radio model to ANAN-G2 along with the relevant Region (UK).
The default Network Settings are
* Reuse Last IP (10:10:30:100 is selected)
* Autodetect protocol
Firewall: Configured correctly
Firmware:
Ver0.0.0
Protocol 2 (v0.0)
ANAN Address:
IP: 192.168.1.76
MAC: "unpopulated" with nothing shown.
A click of the Start button results in a
I have tried troubleshooting using the information on the forums and believe that because my router uses DCHP I needed to set the Select IP to "0.0.0.0" but this still gives the network error with no MAC address allocated on the H/W tab. I then tried ticking the "Enable Static IP address" and manually entering the routers allocated IP of 192.168.1.76 but still have the same outcome.
The G2 had a previous user who may have changed a setting within the units PiHDSDR (it is the display model) that I am unaware of?
I am getting signals on the g@'s display/waterfall so the G2 is working (although I am not getting any audio when I plug my headphones in).
Can anyone help me with some setup troubleshooting please?
I though I was competent enough with computers and LAN's to master the ANAN but am starting to think otherwise
Any and all help gratefully received.
Bob, MI0OTC
Firmware:
Ver0.0.0
Protocol 2 (v0.0)
ANAN Address:
IP: 192.168.1.76
Bob, MI0OTC
