G-2 Fan noise
G-2 Fan noise
after a couple of months of using my G-2, I am experiencing louder than usual fan noise. has anyone else found this issue as well.
Group any recommendations to cure this?
Ed
kk4x
Ed
kk4x
Re: G-2 Fan noise
I’ve had no issue with my fan but I saw this video showing the G2 fan and how easy it’s going to be to swap it out. About the 6:50 mark is the part about the fan.
https://youtu.be/yLDBr-FY9Ao?si=OxaUPHnctd_ykoJd
Good luck
Good luck
Re: G-2 Fan noise
Ed, no issue here, the fan in my G2 is pretty quiet.
73 de KE4WY Jim
73 de KE4WY Jim
Re: G-2 Fan noise
Thank you all that replied.
Ed
kk4x
Ed
kk4x
Re: G-2 Fan noise
I've noticed it as well with my G2. Now if I can find a fan like a Noctua but with the specs of the current fan.
-Brent
N9BC
-Brent
N9BC
N9BC
N9BC
Re: G-2 Fan noise
I think the Fan in the top cover of the G2 is 92mm by 25mm which spins at 2,000rpm.brentc wrote:I've noticed it as well with my G2. Now if I can find a fan like a Noctua but with the specs of the current fan.
-Brent
N9BC
https://www.amazon.com.au/Noctua-Bearin ... Z059O?th=1
73, Phil - VK1HX
Re: G-2 Fan noise
No fan issues with my G2, although I've only owned it for about 2 months. The YouTube link shows the 120mm fan installed by default in the G2. Based on my experience, there's nothing particularly special about this fan. If I were to replace mine, I'd get a Noctua NF-A12x25, which is the same size and a very high quality fan suitable for all-round applications. Link: https://noctua.at/en/nf-a12x25-pwm
The connector is the same 4-pin PWM one as the factory-installed fan. I'd expect the Noctua to replace the factory-installed fan without any issues.
Re: G-2 Fan noise
The Fan you listed above Noctua NF-A12X25 PWM is the wrong voltage. It should be 5V with CFM of 52 also the 4 pin connector will need to be modified as there a two strips of plastic meant to fit in a specific 4 pin connector. If used you will need to trim down those two strips to enable it to fit. also did not see a CFM rating. Maybe someone could find that spec.
Bob KC9RF
Bob KC9RF
Re: G-2 Fan noise
Great catch, Bob. Fortunately it looks like Noctua does make a 5V variant - https://noctua.at/en/nf-a12x25-5v-pwm. The spec states only a 58CFM, which is maybe lower than what Fourdot reports (I find conflicting values when searching). I wonder how accurate the Fourdot fan specs are, though.
