Today I updated Thethis to version 2.10.3.6 x63 and (FW v.2.00 Protocol 2) dev_2. I now have no transmitter output power. Has anyone had such a problem?
Slawomir
No TX output power
laurencebarker
Re: No TX output power
There will be another Thetis release that's associated with the code change to prevent CW TX on an antenna selected for RX. Rick and I worked out what needed to happen and Rick has committed an update but a new release hasn't yet been generated. The solution to that has been a long journey with protocol changes, firmware changes, piHPSDR and Thetis changes. That could be responsible.
What mode are you using? If CW, press MOX on and off after a band change and see if that makes a difference.
And what client app are you using? This issue was resolved in piHPSDR some time ago.
laurencebarker
qst wrote:Today I updated Thethis to version 2.10.3.6 x63 and (FW v.2.00 Protocol 2) dev_2. I now have no transmitter output power. Has anyone had such a problem?
Slawomir
FW v.2.00 Protocol 2) dev_2? Isn't that a firmware release for a non-G2 radio?
I believe it's the fw version that can be seen on the window title bar. Thetis, controling my G2, shows exactly the same version no.laurencebarker wrote:qst wrote:Today I updated Thethis to version 2.10.3.6 x63 and (FW v.2.00 Protocol 2) dev_2. I now have no transmitter output power. Has anyone had such a problem?
Slawomir
Sorry for the mistake. My Tethis version is v.2.10.3.6x64 (01/28/24)dev_2. I don't know why it appears as Hermes in the Firmware setup. I installed the saturnprimary.bin file and got the output back. I haven't tried CW yet. I'll check it out today.
Slawomir
Slawomir
Ron Stockton
I have a new (4 days out of the box) G2 black face that came V10 firmware installed. Radio worked fine using Thetis on an external Windows PC. I work a lot of CW and wanted to avoid the possibility of a momentary RF spike on my RX beverage antennas so I upgraded FPGA firmware to V12. I thought it was a successful upgrade because the P2app listed the firmware as V12.
However, a TX waveform showed on the Thetis TX panadapter screen but no RF output on the internal Fwd Pwr meter or external Bird meter. I re-installed V10 and all is well again. Regrettably, looks like I am stuck with V10 forever.
N0RR
N0RR
Ron Stockton
Roger - Thank you for your reply. However, I am using Thetis on an external W10 computer, not piHPSDR.
73, N0RR
73, N0RR
