SETUP button when pressed shows a blank page
Posted: Sat May 04, 2024 10:23 am
by Vkwayne
I am running Thetis 10.2.2 on my 7000Mk11with inbuilt NUC .Everything has been running well ,until I transmitted on my mobile transceiver on 10m today on an antenna that wasn't connected to the Anan . The power was on, on the Anan , but Thetis was OFF .
I went back to the Anan later and I find that when I press the Setup Button , it opens a window that is blank . I have no access to my settings .
All the other controls work perfectly . I went back to an earlier Database ,no difference ,I removed Thetis and downloaded it again from Github .Still the same.
Anyone had this happen or have an idea what I need to do ?
Regards Wayne
Re: SETUP button when pressed shows a blank page
Posted: Sat May 04, 2024 10:34 am
Have you power cycled the 7000?
Posted: Sat May 04, 2024 10:48 am
by Vkwayne
w-u-2-o wrote:Have you power cycled the 7000?
Yes power cycled the 7000 and PC multiple times after trying everything
