Thetis Development Build 2.10.3.6 dev_3 available
Posted: Sat Jun 08, 2024 2:30 pm
Ed. note: not tacking this because it will change again very soon with a full release...
Development Build for 2.10.3.6 dev_3
This is an in-progress development build for 2.10.3.6. It might be taken down at any time, and/or will probably get replaced without warning. The titlebar will show [dev_3]. Please read the change log below.
Please uninstall any previous version, before installing this version
(Note: uninstalling using add/remove programs, leaves behind your database and does not remove it. You don't need to do anything with this, other than taking a backup perhaps, as Thetis should update/use appropriately)
UPDATE: The CW issue has been resolved for Protocol 2. It requires a firmware update and this modified version of Thetis. Please see the ApacheLab community forums here
Note: You can revisit these release notes by clicking the button in the setup form within the General -> H/W Select tab.
Please report any issue over on GitHub here.
v2.10.3.6 Change Log - WIP dev_3
[add] Fn keys now activate messages directly in the cwx form
[fix] changes to fix issue #407, No TX output when initially going to QSK
[fix] TCI spot would be incorrectly shown if it came from RumLog. Thetis now ignores as string of "nil" which RumLog sends (version dependant)
[fix] attempt to resolve issue where out of array bounds errors are shown at startup
[fix] corrected character display issues in input/output combo boxes (Issue #420)
[fix] websocket protocol close frame message is now sent when TCIserver disconnects a client, preventing some third-party clients from closing improperly
[fix] reworked TCIserver input message buffer to prevent random client disconnects when TCI WebSocket messages arrive rapidly
[change] noise floor approximation now enters 'fast attack' mode more frequently for quicker floor detection (changing modes/antennas/etc)
v2.10.3.6 Change Log - WIP dev 2
[add] -help command line option
[fix] vac mic audio source can now be recorded
[fix] split TXing out of a ham band will no longer disable split when extended mode is used. Note: 'Prevent TX when on different band to RX' option will be used if enabled and TX band has been moved for bandpass/lpf purposes (ie when tx'ing on 11m)
[fix] output power on ANT ports configured as RX only should be resolved. Requires an update to your firmware. See the ApacheLab community forums here #228
[change] the dB shift setting for AGC auto noise floor compensation is now a true shift from NF. You will probably need to tweak your previous setting
[change] the shutdown log is defaulted off. Use command line param -logshutdown to cause Thetis to create a shutdown_log.txt file if you are having shutdown issues which can then be sent in for analysis
