G2- No Local Devices Found
WT4DX
Post by WT4DX »
I attempted to update the G2, and upon booting a piHPSDR- Discovery message indicates that no local devices are found.
This appears to be a software or a hardware issue with the PCI Express interface, the FPGA, or even the R-Pi itself.
Any ideas how to remedy this?
Tem
WT4DX
WT4DX
Re: G2- No Local Devices Found
Post by WT4DX »
Also, when I execute git pull this is the result.
Trucker
Post by Trucker »
Do you have a Github account set up? That might be part of your problem.
WT4DX
Post by WT4DX »
Hi James,
I do have an active GitHub account.
Tem
WT4DX
Trucker
Post by Trucker »
WT4DX wrote:Hi James,
Tem
WT4DX
Ok, from looking at the display in your post it appeared that Github didn't find your email address that is registered with your account.
Maybe, it is how you typed in the command for Git pull. I have had a similar problem in the past trying to update PiHPSDR in my V1 controller. The Linux Command line isn't very forgiving!
Have you updated your G2 before?
K5WC
Post by K5WC »
WT4DX wrote:Also, when I execute git pull this is the result.
check out this for setting your email info
viewtopic.php?f=48&t=4772#p26152
Good luck 73 John
JohnFT61
Post by JohnFT61 »
I have been getting the latest updates from: /github/dl1ycf/pihpsdr
John
N2KBE
WT4DX
Post by WT4DX »
Apache Labs emailed me the G2 Display image, all is well, and the software is updated.
Sadly, I haven't even used the radio yet, and I've owned it for some time. Too many other irons in the fire.
Tem
WT4DX
