USB/BCD Cable option in OC Control
Posted: Fri Oct 11, 2024 12:01 pm
by AndrewK
Question. Is the USB/BCD Cable option a software emulation for the J16 OC pins?
Like to understand how I can make use of this.
Thanks Andrew
Re: USB/BCD Cable option in OC Control
Posted: Fri Oct 11, 2024 1:08 pm
Posted: Fri Oct 11, 2024 2:10 pm
by AndrewK
Thanks Scott
I did see that and get the impression that its software generated and nothing to do with the hardware OC pins. Correct?
If so would be easier than making a OC cable to get band data into a VK-AMP I just put together. VK-AMP uses Yaesu BCD code.
Posted: Fri Oct 11, 2024 2:15 pm
It does not affect the OC outputs on the ANAN. It uses an external USB relay board. It's not clear from the other thread what boards are compatible.
Posted: Fri Oct 11, 2024 2:29 pm
by AndrewK
In the mentioned topic Richard KI4P was playing with a relay board.
Looks like this should meet my requirement, will have a go and report back.
Cheers
Andrew
Posted: Fri Oct 11, 2024 5:03 pm
by Joe
I know this is different from the usb - relay setup but another option is using the OC outputs with a bcd board. I use one supplied by W6PQL, works very well with the Anan. Hope you get it worked out. I added the photo of the board (lower left side), in my amp.
73’s
Posted: Tue Oct 29, 2024 11:59 am
by AndrewK
Thanks for your post Joe.
Reporting back that I can control the VK-AMP by checking the USB/BCD cable option. PC USB to Amp DB9 for band control.
This provides an alternative to making a OC cable ANAN to Amp for band control.
I used this FTDI cable
FTDI-DB9 cable.jpg (3.44 MiB) Viewed 4633 times
Posted: Tue Oct 29, 2024 1:01 pm
by Joe
Thanks for the information. Great option.
73’s
