ANAN-7000DLE MKII NUC I7 (Silver Face) ribbon cable connections
Posted: Sat Nov 16, 2024 3:35 am
by kharaburda
I heard rattle inside my ANAN 7000DLE MKII NUC I7. I took it apart and found a small washer in one of the "dimples" in the huge aluminum heat sink.
I disconnected a few of the ribbon cables in the process. The connection points on the ORION board seemed obvious. But when I went to reattached the last ribbon cable I sadly noticed there were 2 identical header located right next to each other. Oops !!
I hope someone can tell me which header to use.
Kent (KG5UWB)
IMG_2943_hilite-min 3.JPG (529.99 KiB) Viewed 5486 times
Re: ANAN-7000DLE MKII NUC I7 (Silver Face) ribbon cable connections
Posted: Sat Nov 16, 2024 9:44 am
by n1gp
Hi Kent,
It should go to the upper one closest to the metal case, P1.
-Rick / N1GP
Posted: Sat Nov 16, 2024 5:36 pm
by kharaburda
I am back on the air.
Thank you Rick (N1GP)
Posted: Mon Nov 18, 2024 9:45 am
by Tony EI7BMB
I found the off cut of a plastic cable tie in my 7000 :D
