G2 Ultra crashes with external monitor connected
Posted: Thu Dec 05, 2024 11:35 am
Had my G2 ultra (with screen) about a month ..new to sdr's so steep learning curve as not a pc geek.
All is well until i connect an external monitor,then after about an hour the screens freeze and the radio is totally unresponsive,unplugging the monitor has no effect,so unfortunately have no alternative but to press and hold the power button and force shutdown,which i believe can be harmful.
I've fitted large ferrite rings to HDMI and power cable from the monitor as well an numerous clip-on ferrites to all other cables out the back of the radio. I've only played with Thetis briefly,and the radio worked fine with the monitor,so can only conclude the problem is with piHPSDR which is V2.2. My knowledge with computers is very limited,so rather reluctant to start attempting updates etc,because i could end up with a bigger problem/s than i have now
TIA
Nick
TIA
Nick
