out of band transmission
Posted: Mon Jan 13, 2025 3:05 pm
by f6dro
Hello ,
I am using my ANAN10 as an IF for 23cm. 28>30=1296>1298. I am not using the transverter bands but really the normal 28Mhz TX/RX output.
Soon , because of Galileo , we will have to migrate to 1298>1300.
At the moment , it is not possible with anan10/powersdr to TX from 30>32. I understand the restriction , but in case of transverter IF so not antenna transmission, could it be possible to make this possible? I don't know wether it is an anan firmware or Powersdr limitation.
Any help?
Dom/F6DRO
Re: out of band transmission
Posted: Mon Jan 13, 2025 5:06 pm
Are you really still using PowerSDR? Why not Thetis?
In either case, selecting the "extended" option for the region setting should allow operation in the manner you want.
Posted: Tue Jan 14, 2025 9:03 am
by f6dro
w-u-2-o wrote:Are you really still using PowerSDR? Why not Thetis?
Hi all ,
I use both , I'm going to check that , tnx
Dom
